Hot
New
Out stock
xTool M1 Laser Engraver and Vinyl Cutter for School
$1,799.00$2,499.00
- $700.00
Save $250 on Teacher Appreciation Week  Copy Code
xTool M1 10W Basic Educational Bundle
$1,799.00
$2,499.00
Contains xTool M1 10W Laser Engraver and Vinyl Cutter, Smoke Purifie rand Free Gifts
  • xTool M1 10W Laser Engraver and Vinyl Cutter
  • Smoke Purifier:Efficient Smoke Purification Allows You to Enjoy a Quite, Safe and Clean Classroom Environment
  • Free Gifts: Basic Material*1, Adhesive Cutting Mat*2 and 45° Blade*5
xTool M1 10W Premier Educational Bundle
$2,519.00
$3,569.00
Contains xTool M1 10W Laser Engraver and Vinyl Cutter, Smoke Purifier, Air Assist Set, Riser Base with Honeycomb Panel, RA2 Pro and Free Gifts
  • Air Assist Set:For Cleaner and Smoother Laser Cuts
  • Riser Base with Honeycomb Panel:Supports higher objects, helps dissipate heat for cleaner cuts
  • RA2 Pro: 4-In-1 Rotary Supports 90% Cylindrical Engraving.
  • Free Gifts: Basic Material*1, Adhesive Cutting Mat*4, 45° Blade*5, Basswood*18 and Heat Transfer Vinyl Kit (60 Pcs+3 Rolls)
Icon/Attributes/Free shipping Delivered in 3-7 Business Days
Safe & Secure Checkout
Pay Image
Pay Image
Pay Image
icon-theme-126 icon-theme-161 icon-theme-138 icon-theme-027 icon-theme-022 icon-theme-shipping
Secure Payment
12-month Warranty
Free Shipping
30-day Return & Refund
$1,799.00$2,499.00
- $700.00
Normally, a laser cutter can perform very well on many materials such as wood, metal and glass. However, for some soft materials such as vinyl, which can be used for DIY T-shirts, sign making, logos and more, a blade cutter is preferable to avoid the burnt edge, discoloration and toxic fumes generated by laser cutting.
With xTool M1 which has both the laser and blade heads, you don’t have to waver between a laser cutter or a blade cutter (or breaking the bank to buy both). Your ideas can be realized on just one machine.
What You Can Create with xTool M1
Small, Powerful and Accurate
Powerful Enough to Cut Basswood up to 8mm in One Pass
Smart and Easy to Use
16 MP Smart Camera
Equipped with a 16MP high resolution camera inside, xTool M1 can realize visual processing and smooth operation.
Image Extraction
xTool M1 intelligently captures images, designs, and drawings from any surface and then imports them into xTool’s graphic design software for further creative design.
Batch Processing
The AI system automatically detects the shape of the material and processes the same shape of the material in batches at one time.
AI Auto-focus
xTool M1 initiates auto-focusing, including visual identification, material thickness settings and material recognition so you don’t have to set the cutting parameters by yourself.
What's inside the box?
Official Live Demo of xTool M1
Comparison Between Alternatives
Comparison between xTool Products
Comparison between xTool D1 and xTool M1
If you have any further questions, please feel free to contact us via hello@xtool.com.
 Or join our Facebook community to discuss with over 13000 M1-loving crafters & handmade store owners!
Request for Quote
Quotation Notice
1. An email has been sent to you containing the quotation file and all other important files. Please check your mailbox.
2. The quote is valid for 30 days. Please generate your Purchase Order within this period. If the quote expires, a new quote will need to be generated.
Download W9
Download W9
More Support
If you need more help, kindly mail to vendor: us@makeblock.com
